I have gotten a 78 Johnson 55 hp that has been in storage for 15 years. Everything was winterized properly and fuel was drained back then. When I got it and put fuel in it, the engine fired right up. Took it out on the water and it would die after about 5 minutes of running full speed. I checked the carbs and have never seen anything so clean. After reading forums I changed the fitting on the fuel line where it hooks to the tank because as I pumped the bulb bubbles would come out there. This fixed it and it ran great while in gear. But then I had troubles keeping it idling or getting it started. I've since changed out all the fuel lines, fuel filter and pump. Still nothing. It actually is worse now because it will start after a lot of trying and then die after 5 seconds if I'm lucky.
I've taken the fitting off the gas tank and cleaned it as best I could with carb cleaner, but it didn't make a difference. I don't think it's a clogged vent because I have two tanks and either one has the same thing happening. One tank gets vacuum and if you remove the cap can hear the pressure, but the other one doesn't.
I'm lost. It actually is worse after replacing all the stuff. Any suggestions?
