78 Glaxay with a Mercruiser 120 hp
fredfedx1
Help needed:<br /> I have a problem with the boat going in to gear the rpms are at 600 and when I shift it forward it grinds then catchs. In reverse it GRINDS but no catch
Re: 78 Glaxay with a Mercruiser 120 hp
Lower Shift Cable is Where you should be Looking.........
fredfedx1
thank you for your help that did the trick Blk-n-Blu but the only problem i am having now is Adjusting the stearing if anyone can help let me know.
Blk-n-Blu
Master Chief Petty Officer
fred, Do you have power steering? is there a power steering pump on the engine? If not can you describe the steering system.<br />You might try unhooking the outdrive from the steering and seeing if the drive moves freely to isolate the problem. It may be prop torque, if it is look here<br /> http://www.boatered.com/forum/topic.asp?TOPIC_ID=51164
