so was having idle issues so I cleaned the jets and 2 of them were plugged so now where is the idle adjustment and how many rpm's should it be running seems like there are two cables running to the motor the lower I found out adjusts the linkage for the trans. And what should the rpm be at if im adjusting on muffs it just doesn't seem to like to run at idle
not sure if you can see it theres that upper and there is a lower linkage
