randyrandy
- Jul 9, 2008
- 8
I have a 1978 Evinrude 140 hp, with integral trim/tilt unit. I have the original owners manual and it only tells how to top off the reservoir. I want to know how to drain and replace the fluid. It doesn't leak but the fluid is grey/brown and doesn't look healthy (probably 20 year old fluid). There doesn't seem to be a "drain plug," from what I see in the manual. Do I disconnect the fluid lines at the bottom of the unit and let it drain out, then reconnect the lines and fill, or is there more to it than that? The owners manual just refers to topping off fluid and complete rebuild of the unit, nothing about just replacing the fluid. It does say that Dexron ATF is an acceptible alternative to the Evinrude brand hydrolic fluid. I hope I can do this without taking the unit off or pulling the motor off. Help, help, help....and thanks a lot.
