"77 Johnson 35hp electric start conversion
McBarry
Hi, <br />current project is converting the above to electric start. (have starter motor, starter and choke solenoids).<br />This motor has been converted to points at some time in it's life - no lighting/charger coil on alternator plate (I'm told it's a '76 alternator plate..)<br />I'd like to have a go at a charging circuit (ie charger coil and rectifier)to avoid throwing big bucks at the electronic ignition option.<br />would anyone have a schematic of the rectifier - if I can whip one up to test the system and it works OK then I might just invest in the real thing.<br />Thanks for any thoughts,<br />David
