My father-in-law handed down a 1977 Glastron with a 70hp Evinrude to my son. The boat has been covered and mostly sitting on a trailer in the Florida sun for the last 15 - 20 years. I picked it up last weekend and its in pretty good shape. Not sure when the last time the motor was started, probably 3 - 5 years ago. He has always been very good about cleaning the boat, running fresh water through the engine and draining the gas out of th carbs after he used it. My question, I'm not sure if I should replace anything before I attempt to start it. I was thinking of putting a new waterpump kit on it (not aware that it has been changed in last 15 - 20 years) and change the gear lube. I was also thinking of running some seafoam through the engine. Or should I add something to the oil/gas to help lubricate the engine since it has not been used in years. My major concern is dry rot of seals and break down of any lubricants. I don't want to do any damage starting it after it has sat for so many years. Any advice would be appreciated.
