When I place the boat in reverse it just clicks, the prop will turn but not enough to move the boat.
When out of the water I can sometimes get it to go into reverse (engine not running) and turn the engine over by hand by turning the prop. Maybe one out of ten tries. The cable appears to be adjusted ok. The lever is as far back as it'll go..... It should be in reverse.
Is there another adjustment inside the leg or is the bottom pooched?
