77 AMF Crusader W/ ELECTRIC SHIFT LOST FORWARD
So Im Cruising Down The River When All Of A Sudden Boat Just Stops And Engine Revs Up!! My Son Flies Off The Seat Smacks His Head On The Dash. Try To Put In Gear Engine Revs But No Forward! Reverse Works Fine. Checked The Power Feed Into Case Has 12 Volts For Forward And 12volts For Reverse Both Fine. What Now??? Boat Has 302 V8 And I Think Its An Omc Outdrive (has Engine Tilt And Outdrive Tilt If It Helps Any) Have To Wait Until Next Week When We Pull It Out Of The Water...also What Manual Do You Recomend? Any Input Is Greatly Appriceated ...thank You!!
