I bought this as a project boat (no motor wood rotting). I have gutted it down to the ribs...My intentions are to hang a 90 HP mariner tiller that I have on this boat..I need help on transom...Should I have a friend tig weld the insert (that used to be plywood) to the dimensions that I cut the transom down to or stick with plywood laminated with epoxy.. I noticed that the two stringers are kinda of flimsy and are cracked in a few places by the rivit area attached to the ribs...What is your opinion on replacing with some thicker gauge material...I intend to beef up the transom with two "L"supports attaching from the stringer to the transom. I want to go with a diamond plate floor covered in rubber bed liner. Also anybody need any chieftain parts reasonable $...I am cutting the top off and have windows, railings, console, gimbal bearing merc housing ect. ect. Thanks HS
