Hi all
I am hopping someone here can point me in the right direction.
A friend of mine got a "new" boat this year it has a 1977 115hp Johnson motor.
The problem/s
The motor is hard to start we have to spay premix into the carbs to start it.
Once it is running it runs good until you idle for 2-3mins then when you try to go it will stall, you have to "play" with the gas until it clears out then it runs good again.
So far I have rebuilt the fuel pump and the carbs replaced the fuel lines. I have tried to "tweak" the floats started parallel with the carb body, then tried bent back a little (richer) no change.
Any ideas?
Thanks
The problem/s
Any ideas?
Thanks
