Re: '76 Mercury 850 wont crank
Hi there!
I just got this same motor in February. (My first Merc, so don't expect a lot of insight) Try to start troubleshooting with the basics;
1. Known good charged battery
2. Check all connections
3. Go around the solenoid with booster cables right to the starter. (Lots of sparking, look out)
Sounds like your solenoid is working, if it's clicking. A little oil under the bendix will help it to throw out easily and not bind. (Maybe you ran down your battery working on your PTT?)
As far as the manual goes, I bought a Clymer manual right away while I waited for a factory service manual to arrive. Should have just waited, the Clymer was a complete waste of money comparatively. There is particularly very little information about the 850's in there. Haven't looked in a Seloc, but I don't expect much different there.
Good Luck!
