I just purchased this engine and maybe I'm completely blind but I can't find where the water indicator stream should be coming from. When I put the cups on it and turn on the water it streams from a few holes around the lower unit but I cant see anything coming from what would be above the waterline when under power. I'm just curious where you should look to know that your water cooling system is working. Thanks in advance.
