76 japanese mariner 15hp
mnkid
I inherited a 15 hp japanese mariner s13228 which I believe is a 76 long-shaft model. It starts right up but kills after 15-20 seconds. I cleaned fuel tank and replaced fuel hose. Is there a simple test to check fuel pump? What other obvious things should I check? I have a clymer manual but its a bit generic. Is it worth servicing, or should I let my brother use it as an anchor for his floating swim platform. Any <br />thoughts would be appreciated.<br /> MNkid
JB
Re: 76 japanese mariner 15hp
Howdy, MN Kid.<br /><br />What happens if you pump your primer bulb after start? <br /><br />Sounds like it is using up the fuel you pumped in before start and not getting more.<br /><br />Check out your fuel pickup in the tank, fuel lines, primer bulb and hoses for restrictions.<br /><br />If they all check out and pumping the primer bulb keeps her running, overhaul your fuel pump.<br /><br />Good luck. :)
