Smig
- Nov 13, 2005
- 182
Can the flex plate bolts affect flywheel balance? I took the flex plate off to realign the flywheel and did at least one, if not more, dumb thing(s). I know something is wrong because the flywheel makes noise as it goes around - it sounds like metal just barely scraping on plastic and it happens once per revolution. So here is what happened:
1) I broke a bolt putting it back on - will this one bolt head affect the balance? I am not that strong so I don't know how I did it, but it is definitly broken!!
2) I did not put each bolt back into it's original hole - I mixed them up. I read somewhere here that each bolt has a slightly different weight so when the flywheel is built, this is taken into account. Is that true? If so, how do I go about rebalancing it?
Why did I take it off in the first place? Well I am asking myself the same question - I just bought this motor and found that the flywheel was not put back in the right place. The previous owner replaced the trigger and when he put the flywheel back on he aligned the .464 mark on the sticker with the actual TDC of piston #1 making it impossible to time the engine. I took out the 8 bolts of the flex plate, rotated the flywheel and then bolted it back up. Now everything aligns and I can time it properly, but there is that noise and the broken bolt.
Thanks
Shaun
Thanks
Shaun
