With the water muffs the motor runs without issues. In the water, the motor idles well after start, gets into gear fine, when the throttle is pushed past the half way point, it dies. If I run the motor in gear at very low speeds for several minutes and then slam the throttle forward, it boggs down but then it kicks in and runs at full throttle smoothly. After I throttle down it idles high. I have tried pumping the fuel bulb while throttling up but it does not make a difference. It has no thermostat or flow restrictors on the head (left them out on head installation) and the water has been around 65 degrees. Could it be that the motor is too cold to run? I have not check the compression.
