eavega
- Apr 29, 2008
- 1,377
I have a '76 70 HP Johnson (70EL76D) that I suspect has a faulty fuel pump. Although the repair manual states that the pump is not servicable, iBoats had a fuel pump rebuild kit for this motor. I am in the process of rebuilding the pump, but the kid came with no instructions and I need some guidance.
1. Does anyone have a blow-up of the fuel pump? I took pictures as I disassembled the pump, but would feel better with an actual diagram or blow-up of all the parts to make sure everything is where it should be.
2. Do I need to put any kind of gasket sealer between the layers? There is a gasket between the top metal plate and the bottom metal plate. When I disassembled the fuel pump, the existing gasket was pretty much adhered to the plastic part of the pump. I've cleaned most of that off, but didn't know if it needed adhesive when put back together and if so, what type
Any help would be appreciated. I'd rather not have to chuck the whole thing and spring for an $80 fuel pump if a $10 fuel pump rebuild kit will suffice.
Thanks.
Rgds
Thanks.
Rgds
