Okay tried emailing iboats store for a part and they don't have it and iboats suggested i post in here and ask you guys
I need the upper and lower fuel pump for a 1976 200hp evinrude
i don't even know if mine are bad see here iis the thing i bought a 76 20ft ranger with the motor on it, and he had bypassed the fuel pumps and added an electric fuel pump (auto grade) not made for marine use engine starts and runs had it in water and should FLY with just me in it dang thing wont even go 10 mph took it to a local marina said would be around 800 to 1000 to fix all that needs to be done is
all carbs rebuilt
part that the started bolts into needs to be welded back on (still has other 3 bolts holding it on)
and the automotive grade electric pump removed and fuel system set back way meant to be
so any ideas where to get some reasonable priced fuel pumps can be?
all carbs rebuilt
