selanative
- Apr 11, 2013
- 20
After fixing my full throttle problem (changed all three coils) im still having a high idle issue. I dont think my tach is working correctly so its hard to pin point the exact rpms but here in this video you can tell the idle is way high. I tried adjusting the idle speed screw but even all the way backed out nothing changes. Disconnected the linkages to see if that holding the time base in a bind but nothing changed. It seems the only way the timer will retard is by hand but it automatically moves back to the beginning position. it moves about 1/4 inch.
the carbs and throttle plates along with cam roller seem to be all in sync and not out of adjustment.
Notes when i pulled the carbs off i noticed the seal that sits in the carb bowl around the pick up tube has cracks in it so they are on order. (would this cause high idle?) i would think it was cause a bog down.
I also tried to look at the reeds and when i stuck my finger inside the engine i could push down on them and feel them bottom out then come back up.....is that normal?
My throttle linkage is acting all kind of retarded and i keep moving it back and forth but not changes so i just removed it completely and still nothing different.
I dont have any problems starting it at all and fast as i can get off the key its running.
sorry about this being scattered any questions just ask.
http://forums.iboats.com/johnson-ev...issing-choke-solenoid-599850.html#post4182615
