Re: 75hp 4-stroke can't figure this one out
I have a 5-year-old 60 HP 4-stroke and sometimes my engine will die off and just idle rough. I pump the primer bulb and away I go. Here's what I found -- when I changed the filter I found tiny flakes of plastic. Tracked it down to the fuel hose between the inboard tank and engine. The alcohol in the gas was eating the lining out from the inside of the fuel line. Replace the hose and primer bulb. Still had the problem and when I pulled the engine cover I could see the fuel filter bowl was empty. I replaced the snap-on connection at the engine thinking I was sucking air, still had the problem. The filter is clean. I borrowed a portable tank, hose and connector, ran with the lid off the tank to get good tank venting, still had the problem so that points to the engine fuel pump. I removed the pump, took it apart, all the gaskets and diaphram were fine. Some days I can run all over a lake and some days the engine dies from lack of fuel after 5 minutes. Some days it does it at full throttle and some days at idle. Not wanting to take my boat to a shop I put a fuel primer hose on that will reach to the back of the driver's seat. When the engine starts to die off I just reach back and pump the bulb and away I go. It's a cheap fix for an intermitten problem. I also add Star Tron to the gas to overcome the effects of the alcohol in the gas. If my problem doesn't get any worse I'll be happy to live with my solution.
