The motor is a 1963 75hp Evinrude Speedfour, model number 75353. I recently worked on the magneto and got the motor running for the first time in many, many years. The timing marks are aligned properly. <br /><br />1. Can somebody post the procedure for adjusting the timing advance linkage that connects to the throttle<br /><br />2. Can somebody post the procedure for adjusting the idle bleed valves on the carb<br /><br />Thanks!
