Re: 75" Stinger 75HP Doggie on take off.
UPDATE- Had the carb's rebuilt and the water pump replaced by a certified marine tech. He checked out the engine as well while he had it. Compression was 135, 133 & 138, spark was good, timing was set at 17 degrees. He tested lower end for leaks (none found).
Took it out today for the first time since at the shop. Pretty much the same result- it will stay running when put into forward but still stalls when put into reverse. (Ever try launching and docking a big heavy boat without reverse?). Its so doggie you wouldn't believe it unless you seen it. Takes about 300 yards to get up on plane. Runs out good at WOT but still seems labored.
Needless to say I'm about to scrape the MC numbers off the boat, pull the drain plug and waive Good-Bye to this 350 pound orange anchor. It has a 13.25X17 prop on it. Does anyone think this may be too big, or have the wrong pitch? Any advice would be great-- I'm at whits end!!! Thanks.
