75 Mercury missing kill switch
rhomesteader
I have a 75 Mercury outboard motor. I beleive it is a 7.5 Hp. About 1974 serial #3933403. The kill switch is missing. Question 1 - Where can I get a new switch? Question 2 - Does it ground to run or does it ground to kill?
Laddies
Banned
Re: 75 Mercury missing kill switch
Goto the BAM Marine site for purchase, you will need the serial number for the part or the other answer.
rhomesteader
No info from BAM. I believe I have found a replacement stop switch but I would like to see the motor run before putting $90 in to the new switch.
So will it run with out the stop switch? (I will have to do some additional repairs before I can even attempt to start it.)
Laddies
Banned
Same question whats the serial number?
AMD Rules
s/n 3933403 circa 1974
It will run without the stop switch.
Merc p/n 59065A4
Lone Duck
Master Chief Petty Officer
I think the ground kills it. In a pinch you can hook up any toggle switch that runs to ground.
AMD Rules
Check out eBay Item number: 160191813350
Not mine... just an FYI
