I have a 75 Mercury 850, SN below 4366801, on a 1976 AMC runabout. I had a compression check done about a year and a half ago that was all cylinders above 120. I had the distributor replaced as well. It has really run great since then other than just being a little rough on occasion. I recently ran sea foam and deep creep through it. It seemed to make it run a little smoother. I took it out this past weekend and ran it pretty hard for about 30 minutes. I anchored for about 30-40 minutes and then tried to crank it and got nothing. I cleaned the plugs and checked the timing belt and tried to crank it. All I get now is a periodic backfire through the exhaust and an almost clunk sound (dont know how else to describe it) that stops the engine from cranking for about 2 seconds and then it cranks more and does it all again. I am baffled and afraid. I am afraid that something internal busted but it didnt give any indications while it was running. Do you have any ideas?
