75 HP Johnson, 1983? Fuel Troubles
salukee
Based on what I have read here, my Model No. J75TLCE makes this an 83 model.<br /><br />Engine starts and idles fine. When throttle is adjusted there is a slight increase in speed - to about 3 mph. <br /><br />There is a priming valve to be used when manually starting engine. If you move the priming valve from the run position to the midway position the boat accelerates to about 20 mph. While the priming valve is in this mid position fuel is spilling into the engine compartment off the head of the priming valve from an open hose nipple. There are two nipples on the head, one is open and one has a hose leading to the top side of the lower carberator. Boat runs fast, but very poor fuel efficiency and seems mighty dangerous. <br /><br />Sometimes when the valve is closed I lose 1 - 2 mph but still keep moving on. Other times the boat slows back to ~3 mph.<br /><br />I have no idea what the problem is. Any help is appreciated.
Joe Reeves
Re: 75 HP Johnson, 1983? Fuel Troubles
Salukee.... The "CE" in the model number indicates that the engine is a 1989 model. If it was a 1983 model, those letters would be "CT".<br /><br />Check to make sure that you have compression and spark on all cylinders.<br /><br />The fuel primer lever is obviously faulty. Turning that 180° would allow fuel to flow through it to the intake manifold area. Fuel should not flow out the primer control lever iitself.<br /><br />On the fuel primer, there should be two small hoses and one larger hose. The larger hose would be the fuel supply to the primer. The smaller hoses, when the primer is energized (pushing the key switch in), would supply fuel to the intake manifold area via the carburetors as you mentioned.<br /><br />From what you've said, I am visualizing that there is only one small hose connected to the primer solenoid. This being the case, whenever the solenoid is energized, fuel would shoot out of the small fitting that has no hose connected to it. Obviously this will require correcting.<br /><br />The fact that when you turn the actuating lever on the primer solenoid, the rpms increase, would indicate that the carburetors are fouled, clogged, gummed. The cure would be to remove, clean, and rebuild them.
