I have a 1983 75hp evinrude outboard 3 cylinder model# E75TRLCTE. When the motor runs out of water and hooked to a hose, it runs and idles great. When I put the boat in the lake, the motor starts strong and idles great. When I advance the throttle forward to fast the motor bogs down and wants to die at about half throttle. If I back off the throttle and slowly throttle down the motor it will push through to top speed (30-35 mph) and it will run great at top speed. If I hit the choke when the motor is bogging down it makes it worse. After running the motor I see fuel coming out of the air intake of all 3 carburetors. Also, after running the motor you can see black fuel running down the side of the motor leaking from somewhere. I strongly believe that motor is choking itself out but I'm not sure how or why. I don?t know if it has something to deal with the timing advancing forward to so? I have had the carburetors completely rebuilt twice in the last year by to different mechanics and I have replaced everything that has to deal with the fuel system: tanks, fuel line, fuel bulbs, fuel pump, electric choke, etc. Can anyone help me on this problem? I am all out of Ideas and money.
