Re: 75 evinrude 85hp
It should fit-it is the same type of unit. The swivel bracket is the same part number between the two engines: it must have the same holes drilled for the lift bracket so you should be ok. Make sure it works (esp the motor/pump) and that you get all the parts during the swap, as many of them are NLA.
