74 Volvo Penta AQ130 maintenance questions
svracer
I recently received a 74 Dixie trihull from a family member that has been sitting for a minimum of 5 years. Motor from the best of my research is a Volvo AQ130 (sticker on flame arrestor cover says Chrysler Marine, volvo 130 with an outdrive that says Chrysler Marine with a 270 on it. <br />engine block number 1283/88572<br /><br />I took the carbs apart and cleaned them throughly and actually have the thing running. My questions are:<br /><br />What type of engine oil should I use? I was thinking 30wt but saw some marine specific 15w-40 at Walmart. <br />Anyone know what oil filter to use? It currently has a Napa Gold 1307<br />Sparkplugs? Currently has Champion QL82YC<br /><br />What type of oil goes in the lower unit of the outdrive? I go the impression from reading something that these old units used engine oil instead of the standard 75W lower unit oil.<br /><br />Which manual is better Seloc or Clymer?<br /><br />Any other thing I should know about this setup?<br /><br />That's all for now. Thanks in advance.
Peter J Fraser
Re: 74 Volvo Penta AQ130 maintenance questions
This should be the page for the Electric Tilt models AQ130 / 270 specs <br />Or if you have Hydraulic trim then this will most probably be correct AQ130 / 270T specs <br /><br />I prefer the SELOC's manual.<br />The OEM books are hard to get now.<br />Use a premium 15w40 oil for your engine, and the out drive uses the same oil in most cases.<br />SOme one will correct me if the latter is wrong.<br /><br />Good luck,<br /><br />Regards<br /><br />Peter
Don S
Volvo changed from stating the use of "engine oil" to using 30W oil instead of a multi weight oil in the outdrives. It doesn't break down as fast in the drive.<br />30W is also fine for the engine.
Peter J Fraser
Thanks Don for the update.<br /><br />Pete
svracer
Thanks for the info guys.<br /><br />Is there a preference for engine oil between the 15-40 or the 30wt or does it just boil down to personal preference?<br /><br />Barry
Don S
Personal preference is it for the engine. Change the oil and filter at least yearly or every 100 hours and it won't matter what you use.
svracer
What is the deal with "Chrysler Marine" Were they partners with Volvo back in the day?
