Ok bear with me for a little story and some history...
Basically I was clearing some land for my father in law... Cut down a few trees and look there is a boat! (His response, oh that?s where I left it)... Long story short I acquired the boat with the motor mentioned in the title. Estimated sit time was approx 10 years
I was young and in a hurry and put a new timing belt on it hooked up some fuel, sprayed some carb cleaner set a rude time and she ran... never well, fouled plugs, idle was horrible, studder on accel etc.. Bad running and no surprise still used it as a run around for a year or 2.
Fast forward another 2 years of sitting I decided to pull it out and make it run right. Before doing anything I pulled the plugs and did a compression check with a good gauge.
#1 I pulled 135# (I thought the throttle was staying WOT but later realized it closed, so the #1 measurement was taken with throttle closed.. oops, all other measurements were taken at WOT)
#2 145#
#3 145#
Sprayed some light lubricant into each and retested
#1 150#
#2 160#
#3 160#
Ok, so I started pulling covers etc... Front, sides, intake exhaust as I knew this motor has eaten a few water pumps so I wanted to make sure paths were clean and peace of mind for me...
So far this is what I know what I want to do:
Replace water impeller
Replace Thermostat and poppet thingy...
New cover gaskets
Carb rebuild
Fuel pump rebuild
New hoses throughout
New wires where required
New plugs
Ok so here is the question... Do I pull the head to check pistons and cylinders? Or with the compression readings I took am I ok?
Decision is the difference from spending a good bit of money... New seals, new gaskets, new rings etc...
What is the general recommendation? Money is always tight, but want to still make the smart choice...
Question #2... The flywheel has been unbolted before (8 bolts removed, not pulled) and I doubt it was placed on in the same orientation... How can I ensure it is on correctly? There are no timing stickers or marks that I know of on the flywheel. I plan on placing a timing sticker and needle once I'm ready to set TDC etc... I have heard that the flywheel has to be oriented correctly, but I didn't know if it had something to do with the stator or something, or if it was just due to lining up timing marks in which case it doesn't matter to me as I have none.
Question #3 at some point in history when a water pump was replaced I'm sure the little piece that activates the reverse lock (arms that lower onto the pin to keep the motor from jumping)... What is that piece called!!
And where can I buy!! Plastic piece I believe...
I'm sure I will have more questions as I dig into this and I appreciate any response. This forum has helped me in the past, a lot of knowledgeable people on here...
Thanks
Brian
Serial Nubmer is a 381..... I'll report the full number when I look again..
#2 145#
#3 145#
#1 150#
#2 160#
#3 160#
New cover gaskets
Carb rebuild
Fuel pump rebuild
New plugs
Thanks
Brian
