michigamiman
- Aug 3, 2017
- 6
I have a Johnson v4 115 hp that has lost power and now has no/weak spark. One day, while on plane & cruising along there was a cough & sputter then died out. Got it restarted, and barely got it to fire back up to get to the dock as it wanted to die with any acceleration. I bought new cdi coils(all 4) and swapped out for an extra used powerpack I had. All seemed well. Every so often it would seem to loose power, or not want to accelerate up onto plane. This season's first out it barely was able to get on plane due to the loss of power, but after a couple of laps on the lake it seemed to come back to full life. The next fees times I tried to get out the power was gone. Was barely able to get on plane. After removing, and cleaning carbs, and making sure I didn't have a fuel delivery issue (which I am very familiar with in these older motors). Next, I tested the spark with a gap tester, and found the issue -#1 weak spark #2 good spark #3&4 had no spark. So, in my ignorance I ordered a new power pack (cdi brand). I put it on and went for a test drive. It fired up great, and seemed at idle to be like new again. I let it warm up for a few minutes, then went into a normal acceleration onto plane. It was a huge improvement and felt as if all cylinders were firing, but it was not back to full power. Half way round the lake, it coughed and died. It barely fired back up, and barely ran well enough to put to the launch. After getting to the garage I see that the rectifier wired wrong(the red and yellow wires were reversed). The plastic insides were melted down the block. Now I just got this engine last summer and ran it wired like this since cuz I never looked at or changed any of the wiring, and it ran great when I got it. I took a rectifier off another motor that ran great till I stole it's power pack, and put it on. I went for a test run. It fired and idled way better then when I gimped it in last trip, but had no power, and would only mush hard, and not get on plane. I am afraid I tried my new power pack due to the backwards wiring of the rectifier. I am getting to swap the stator, and timing plate from the other motor that ran great til I robbed the power pack to get this one going... So, am I on the right track, and did I try my new power pack??? PLEASE HELP!! THANK YOU...
