74' Johnson Javlin 85 Wiring for timer base
Javlin85
Last year I had a boat shop look at my motor because it was idling fine, but anything past half throttle and it would bog down. I rebuilt the carbs and replaced the plugs but made no difference. The boat shop(just some Gomer with a tin shed and a 'BOAT REPARE' sign........I know it's misspelled) said that the compression was fine and suggested the timing base was bad. He wanted $700 to repair it. I told him I would retire it and paid him $200 for diagnosis. To make a long story even longer, he left off all of the screws on the terminal strip at the back of the motor. He also kept the terminal strip cover. I assume the wiring chart was printed on the cover.<br /><br />Does anyone know what the wiring layout is for a 1974 Johnson Javlin 85HP. I want to try out my new timing base.<br /><br />Thanks
JB
Re: 74' Johnson Javlin 85 Wiring for timer base
Ahoy, Javelin. Do you need timer to CD ignition unit wiring or only the 8 point terminal strip?<br /><br />If all wires are off the terminal strip it is immaterial which end you designate as pin 1. <br /><br />Pin 1: Not assigned on the wiring diagram.<br />Pin 2: Purple and white, from plug to choke solenoid.<br />Pin 3: Purple, From plug to thermo switch.<br />Pin 4: Yellow and purple, Thermo switch to choke solenoid.<br />Pin 5: Yellow, from Timer base to rectifier.<br />Pin 6: Gray and yellow from timer base, other side open.<br />Pin 7: Gray from plug, gray and yellow to rectifier* (I checked this several times and compared to other V4s)<br />Pin 8: Red, from starter solenoid to rectifier.<br /><br />* on 1977 V4s pins 6 and 7 are jumpered together. The gray lead from the plug is a tach lead and the gray and yellow from the timer to the strip is a tach signal.<br /><br />If you need the connections to the CD unit, holler.<br /><br />Red sky at night. . . . <br />JB
JB
Forgot to mention: Maggot Motors probably didn't have a clue. You didn't mention the fuel pump or fuel system before the carbs. That is a more likely source of your problem than a timer base, but it is cheap and easy to fix. Timer bases and labor to change them, on the other hand, are very profitable.<br /><br />Good luck, and if it aint fixed yet, inspect the whole fuel system and overhaul your fuel pump.<br /><br />Red sky. . . <br />JB
Javlin85
WOW!!! JD, you 'da man'!!! The motor I have has a 10 point screw terminal where the 4 timer base wires run. It also has connections for the coils and plugs on the same strip. That's what I need help figuring out.
Javlin85
See....you were so nice that I forgot to proof read my reply. Sorry JB
JB
Hmmm. I am looking at a diagram for '74 to '76 V4 engines. There is a 9 point terminal strip on which only 8 are used. There are 12 connections to the CD unit, including 4 for the coils, 6 for the "Timer Stator and Charge Coil Assy" and one from the main cable (ignition kill from key switch). Is the CD unit wiring what you need?<br /><br />Standing by.<br /><br />JB
JB
Okay, Javelin. Here we go:<br />PIn 1: Black and yellow from main plug.<br />Pin 2: Black and white from timer/stator unit.<br />Pin 3: Orange from coil#2<br />Pin 4: White and black from timer/stator.<br />Pin 5: Orange from coil#4<br />Pin 6: Black to ground.<br />Pin 7: Brown from timer/stator<br />Pin 8: Brown and yellow from timer/stator<br />Pin 9: White and black from timer/stator. (Yes, this is the second one, but I can't see any difference to ID them from onr another. Same with the black and white wires.)<br />Pin 10: Orange from coil#1<br />Pin 11: Orange ffrom coil#3<br />Pin 12: Black and white from Timer/stator<br /><br />I am going to guess that the two pairs (2 Black/white and 2 White/black) are the same and are interchangable, since the output terminals they come from on the timer/stator unit are not numbered on the diagram. If it helps, the pair that go to pins 2 and 4 are adjacent and the pair that go to pins 9 and 12 are adjacent at the output of the timer/stator unit.<br /><br />I sure like the V4s that have 2 identical 2 cylinder ignition systems better. SOOooo much easier to troubleshoot and cheaper to repair.<br /><br />Hope this helps.<br /><br />Good luck.<br />Red sky at night. . . <br />JB
