newtowater
- May 13, 2009
- 11
Engine fires up immediately in back yard with muffs on and stays running untill either I turn key off or if I push throttle lever all the way down. It will always start back up quickly. The bottom carb throttle lever has a little bit of play to it and mechanic told me it will have a rough idle. When I put it in the water though, it will only idle for a few minutes at a time, will shut off immediately after attempting to put in gear and will only stay idling as long as I hit the choke toggle every 30-45 seconds. Has new plugs and just had carbs cleaned. Any ideas would be helpful. Thanks.
