74 Johnson 70hp electric fuel pump?
huntxtrm
I have a 74 Johnson 70 hp, I'm considering by passing the stock fuel pump, and installing an electric fuel pump. My fuel tank is a built in tank, and I want to get away from squeezing that primer bulb. Can this be done? What fuel pressure should I run? Any tips would be appreciated. Thanks
Chinewalker
Re: 74 Johnson 70hp electric fuel pump?
If bulb, hose and fittings are in good shape, there isn't much need for priming the bulb regularly. It is NOT recommended that you use an electric pump for safety reasons.
Daviet
Chinewalker is correct, NO electric fuel pump, there is no way to control fuel flow if a fuel line breaks.
huntxtrm
What safety reasons? Please explain. It's just it seems to me the fuel system on these older motors are expensive, and unreliable. Larger boats have electric fuel pumps, right?
Daviet
As I said in post #3, there is no way to control the fuel flow if a fuel line breaks or is leaking. Fuel/fumes under the cowel of an outboard with coils and spark plugs is a dangerous mix.
huntxtrm
I see your point, but, if a fuel line breaks with a manual pump, wouldn't fuel still be released under the cowl for a time, until the motor runs out of fuel. I thought the newer motors have electric pumps, because of the fuel injection. How do they avoid this problem? I do see your point, not arguing the fact, just trying to engineer around it. But if it can't be done safely, then it won't be done. I was going to put the pump, down by the fuel tank, if that makes a difference?
clanton
Electric pump is OK, if you rig it to stop pumping, about 10-15 seconds if engine does not start, and stops pumping if engine stalls, or stops running.
boobie
Clanton said it all.
huntxtrm
Sounds to complicated for right now. Maybe in the future. Thanks for the info, and on how to go about it safely.. Thanks for looking out for my safety, and my boats.
