I just bought a Johnson 15hp motor. It runs great but no water coming out of pee hole. I checked the water pump and all seems good. I will replace soon to be on safe side. I put a hose on the tube that goes from the pump up to the powerhead and blew into it and if I blow as hard as I can I can hear very little air. Is something clogged? Is it possible the t-stat bad or is there something else I should be looking for. Any help is appreciated. Thanks
