74 EVINRUDE no spark
KXP
I charged the battery because i had no spark someb0ody told to me to here. It will try to start then it will smoke. then if try again it wont try to start again.any ideas anybody.
Greg22
Re: 74 EVINRUDE no spark
I would get a manual and start in the electrical section. You will need a mutlimeter to do some of the test. Not sure, but if your motor has coils I would check them. The book will tell you how to do this task. I would do an ohm check on the coils and see if they are the same (or within 10% or so of each other. Good Luck.
OBJ
Ken...could you post the HP please. Thanks.
KXP
sorry its a 70hp i have a factory manuel is this what you are referring to.
Greg22
What you need is a repair/service manual.
