I have a 74 85 HP Johnson on a 1960 Flying Scott, the engine has a bad habit of jumping up when I put it in reverse, I would guess this is mostly operator error than it is anything else. The pin that holds the engine in position does not go into the body of the engine, but runs behind it through the two bracket holes. There is a hole in the body of the engine were a pin might go, I'm not sure if one goes there or not.<br /><br />The problem I have is I seem to have broken the seal were the engine bolts through the transom and one of the bolts trickles water in the boat. I was told that it should be fixed right away. Bellow the larger bolt is a small one, so I am guessing there are four bolts holding the engine on the transom. Could I make a support of some kind to go under the engine and then take out one bolt at a time spread 101 sealer around the inside of the hole, let it set up, then apply the sealer to the washer and bolt tighten it just short of snug, once it sets up tighten it down and apply sealer around the outside of the bolts? On the other hand, should I take it to a shop to be sure it is done right? Thanks again for any help with this.<br /><br />Don
