74 70hp johnson Tach wire location?
blueboat1
I just picked up a 74 70hp Johnson. I have the old tach in my boat and wondering where :confused: the signal wire hooks up on the outboard wires/board? the tach post says signal<br />Thanks for the info.<br />Happy boating<br />Scott
OBJ
Re: 74 70hp johnson Tach wire location?
Hi ya' Tin Can....<br /><br />On OMC (now Bombardier) engines, the tach wire is the gray wire in the wire harness. Connect the gray wire to the "Signal" post on the tach. It should be in the harness that goes up towards the dash. Most likely it will be "Taped" off.
Hooty
Welcome to iboats Tin Can,<br />It connects to the gray and yellow wire on the rectifier.<br /><br /> Tach Problems <br /><br />c/6<br /><br />Hooty
