73 Johnson 125 w/ no fire
rickdog67emtp
I have the above motor which I have used the past couple of seasons with a little problem with ignition. Now, after successfully running the boat last week, It now wont start. Plugs are wet when removed, compression around 130 on all four. No spark at any cylinder. It appera that someone has removed what I thought was a mercury switch and just taped the ends off(no chance of touching). Power pack seems to be fairly new.I had unhooked the main harness to jump the solenoid so I could rule out the ignition switch. My solenoid has the battery input and starter out, but also has two small wires in. The lower one starts it, but what does the other small wire do? Also, I havent had the flywheel off so I wasnt sure whether this motor had points. Any suggestions?
Joe Reeves
Re: 73 Johnson 125 w/ no fire
The other 3/8" hex head nut terminal is a ground.<br /><br />OMC did not make a 125hp engine in 1973. What is the model number of your engine?
papasage
there bis a fuse on the powerhead that could be blown<br />it is a inline fuse . the nutral safty switch .gearshift not in nutral hold the kay in the on position and move the shifter backand forth . could be a bad conection .clipper circuitfauliy.
Joe Reeves
Rick... The 1972 125hp Johnson has what is called "Battery Capacitance Discharge" ignition, meaning that it is dependent on having 12 volts supplied to it from a battery.<br /><br />Pulling the main electrical connector apart on that model eliminate all voltage being supplied to the powerpack etc!<br /><br />You can test the powerpack as follows, and if you should need a new pack and cannot locate one at a reasonable figure, contact me at my address below.<br /><br />The following may give you some insight on your problem:<br /><br />(Battery Capacitance Dischage Powerpack Test)<br />Various OMC Engines - 1968 to 1972)<br />(J. Reeves)<br /><br />Purchase a small 12v bulb at your local automotive parts store (the 12v bulb is to look like a flashlight bulb, not a headlight bulb). Solder two wires to that bulb, one to the side of the bulb (ground), and the other to the positive point. <br /><br />Remove the spark plugs. With the key in the on position, make sure that you have 12v going to the pack at the terminal block (purple wire). Now, connect the ground wire from the bulb to any powerhead ground. Connect the wire from the positive point of that bulb to the powerpack wire that is connected to the coil wire on the terminal board (blue wire). <br /><br />Crank the engine and observe that bulb closely (CLOSELY!). If that bulb glows even the slightest bit, the powerpack is okay. It may be a very dim glow... just so it glows! If it doesn't glow, the pack has failed. <br /><br />Keep in mind, that type powerpack (Battery Capacitance Discharge) demands a top notch battery of at least 70 amp hours. Any less will, in time, cause powerpack failure.
rickdog67emtp
Thanx for the info so far. I have power to the purple wire, the one bridged to it, and the one to the right (8,9,10)w/ ignition switch on. I didnt have a flashlight bulb so I wasnt able to do the bulb check yet. Tried with a test light that had a small bulb but didnt see anything. Thats wierd how it works, than a week later it doesnt. I did accidently leave the battery hooked up for about a week (ignition was off). Just got a manual today.<br />Rick
JESSIELSMALL
can you tell me if the 1991 200hp johnson have the capacitance discharge ignition also. for i am having the same problem.
