Here we go..<br /><br />Reasonably charged strong battery.. Put spark light onto engine between plug and plug wire.. Crank crank crank.. NO SPARK!<br /><br />Put on jump cabled.. Crank crank crank SOME SPARK sometimes..<br /><br />Pull out all 4 spark plugs.. Ground plug with spark light on it.. CRANK CRANK CRANK plugs are firing even ones not well grounded are jumping<br /><br />Put plugs back into motor.. Leave spark light installed.. Pull jumper cables.. CRANKING once again and no spark whatsoever..<br /><br />Any guesses as to the problem? <br /><br />Thanks!<br />Nate
