73 evinrude 6hp water pump replacement
crxess
Re: 73 evinrude 6hp water pump replacement
Remove motor cowl
Remove 4 bolts holding lower to mid-section. Carefully lower While turning flywheel to align pin in upper end of drive shaft with slot in top of mid section.
Once unit is about 1" open, remove screw in shift coupling to separate shift rods. Carefully remove lower unit.
Remove pin from top of drive shaft
remove 4 water pump housing screws.
Remove water pump.(Take note of direction of pump twist)
Vic.S
Essentially its just a question of dropping off the gearcase. The pump is mounted on the top of it. However the shift rod is in two parts and the joint between the two has to be undone. Not sure if that accessible once the gearcase is lowered a bit or if there is a rubber plug on the leg to access it (the former I think) I also notice that there are a lot of bits and pieces at the top of the drive shaft on this one.
You may just need an impeller kit or you may need a pump repair kit. the later contains just about all the parts of the pump and a new drive-shaft oil seal.
THIS DIGRAM shows it all and all the parts of the gearcase as well!
The acquisition of a manual would be an advisory first step.
