Now I'm lost. Motor lays flat around 2000 RPM, maybe less. Nothing increases RPM except running in neutral.
Basstender 10.2 rated 7HP Max
Work done:
Head Gasket replaced
Thermostat replaced
Impeller replaced
Carb rebuilt w/kit
Points set to .020
New plugs .030
lower oil changed
Replaced tiller arm
Prop tightened
Test:
Compression 60/60
Fuel pump flows well
Bulb pumps up tight and holds
Good spark
Idle setting decent
Power test under load:
Pull lower plug wire motor lays down - keeps running
Pull upper plug wire motor lays down - keeps running
Good hot spark. refired either plug from 1"+ knocked me silly.
Spray pre-mix into carb motor bogs down
Spray very lightly into carb RPM drops.
Noticed slight wear on throttle cam. opened carb further by hand - no change.
At this point I will gladly entertain any and all suggestions, speculations......etc.
Work done:
Thermostat replaced
Impeller replaced
Carb rebuilt w/kit
Points set to .020
New plugs .030
lower oil changed
Replaced tiller arm
Prop tightened
Test:
Compression 60/60
Good spark
Idle setting decent
