I have a 73 50hp 4cil mercury. Overheated at lake so brought home and replaced impeller which was the problem . After doing this I ran water thru muff none cameout the pee hole however it do come out the prop and around the lower unit. When I flush from the pee hole it comes out around the lower unit where it bolts to the motor. Not sure if I explained that very well.Also dripping water slowly around bottom spark plug. Not sure where to go from here.
