I bought a project boat last weekend (first boat ever) and it has a 72 Johnson Electric start Long shaft.
The guy said he blew the starter fuse and left the key on so it didn't have any juice. Motor seemed to have good compression and the ignition coils look brand new, it seemed like it was worth the 250.00 I gave for it.
I got it home and discover the fuse was fine, and the battery was charged. The motor wouldn't turn over because the neutral indicator (on the motor block) wasn't completing ground, got past that, it turns over good now, but no spark at all.
I noticed the red wire on the reticulator was chafed and exposed, replaced it. Took a wild guess and replaced the power pack, still no spark.
I broke open the control box last night and the neutral indicator switch in there was a mess (but it still allowed it to turn over) I've got it straight wired now.
I don't have an ohm meter (and wouldn't really know how to use one) but It appears that the ignition switch is working properly, and I think I'm getting some power to the power pack, it's just that the orange terminals never fire. (yes I tried with the black yellow disconnected as well)
Stator? Timing Base? Am I missing a possible ground/kill switch somewhere? Do stators totally die or should I be getting a weak current from it?
