'72 Johnson Power Problems
ncbroden
I have a 1972 Johnson 25hp that is attached to a 14 foot lund. My problem is that it the boat will not plane. When running the motor it seems like the motor is not running at full power. I have changed the plugs and installed a new prop but no change. Any ideas?
trumpetbucks
Re: '72 Johnson Power Problems
NCBroden:<br /><br />Welcome to iBoats!<br /><br />Can you tell us how many RPMs you are getting at WOT and how fast you are going?<br /><br />If it seems to you the motor is not running full out, I would check the compression. You could probably do a decarb to help improve that (use the SEARCH feature here and look up "decarb").<br /><br />What size and pitch prop did you have before and what did you change it to?<br /><br />Sorry for all the questions, but this info will help us give you more specific pointers.
ncbroden
Thanks for the response. I am new to boat motor repair and I am just about ready to take the motor in and have someone look at it but I thought I would try here for any "simple things" I could do.<br /><br />I am not sure of the RPM's or speed but the motor had a 91/4 x 11 prop and I replaced it with the same.<br /><br />Thanks again for your reply, if there isn't anything simple you can recommend I will just take it in. Thanks :)
