72 Johnson 50hp fuel pump issue
robtown
Had a little mishap this past weekend. Plug in the bottom carb float bowl worked its way out. There was even a little fire. Got past all that and made it in under my own power. Didn't see that the plug was out until yesterday when I was on dry ground and looking real close, found it and replaced it.
My issue now is after replacing the plug and looking everything over real close for any other fuel leaks, I squeezed the primer bulb a couple times to see if it would stay firm, as I did this and watched the fuel pump I saw fuel coming out of a small hole on the backside of the pump.
Is this some sort of built in pressure relief hole/valve, or should that not be happening? I figured I'd ask before running out and spending 79.00 on a new pump assembly...
bgbass.1
Re: 72 Johnson 50hp fuel pump issue
It sounds like diaphram no good you can buy a rebuild kit
