dkonrai
- May 9, 2009
- 719
72 johnson 25 hp, tiller short shaft.
rebuilding the lower unit and i have a manual. the old ds and ps seals are one piece and the replacement is a two piece.
ordered a sierra 18 2684. do i just install one seal on for the drive shaft and propshaft? if i double the seals on the ds, it seems like it will be a little tall in profile. which way do i set the seals, i assume the flat side towards the gear, and the upper would be flat side up (facing the tower).
would it be ok to use one seal vs two?
do i use gasket seal on the main bearing carrier? it looks like the old was sealed.
the good is the gear and lutch dog look almost new
so glad that there was not a whole lot of wear.
manual calls to use a silicone to seal the spaghetti seal, ok to use regular 100 % waterproof silicone?
sorry for so many questions but this is the first of four that i will be rebuilding and dont want to mess up. waiting for parts isnt my favorite pastime, because i screwed up and had to order replacements:facepalm:
dino
dino
