67lasvegas
- May 21, 2012
- 5
Okay second post since finding this site--See if I give you enough data to help me out:redface:
The boat is a 19' open bow fiberglass "Seira Las Vegas" boat it weighs about 2000#, seems wide. seems to sit low in the water. It is a tri-hull. It is rated to carry 6 people and much of the time I have that many in the boat for looking around the lake.
It has a 135HP Johnson (low profile?) V4 1972 with updated 1974 ignition.
I currently am running a 13 3/4 15 pitch AL prop, This gets me to around 40MPH at about 4500 to 5000 RPM which is my preffered speed for this outboard per my manual.
I have a 13 3/4 17 pitch al prop which I may try for general touring around the lake.
With the 15 pitch and the boat fully loaded I get to plane in okay time but nothing spectacular. With only two people in the boat the nose comes up high until I plane but it is quicker.
Problem is when I try and pull a skier. I usually have 4 in the boat and one in the water. I don't seem to come up quick enough. Would a 13 pitch be okay to run to get up quicker or would this cause some other problems?
Thanks
Thanks
