Re: 72 johnson 125 shorting out
Rick.... If that component isn't surrounded by a metal case, but is rather an expoxy glob, it's a shift diode.<br /><br />A clipper circuit and also a rectifier has a surrounding metal case.<br /><br />You can test that shift diode with an ohm meter. <br /><br />1st Test - With the RED ohm meter lead connected to the "Purple/Green", touch the Black ohm meter lead to the "Yellow" wire, then to the "Yellow/Gray" wire.<br /><br />2nd Test - Now, reverse the connection by having the Black ohm meter lead connected to the "Purple/Green" wire, then touch the Red lead to the Yellow wire, then to the Yellow/Gray wire.<br /><br />You should get a reading with one test but not the other. Any deviation from this such as a reading in both directions, or no reading in either direction (on any wire) indicates the diode is faulty.
