Hello again all, my previous post was a overall "help me" thread..... now that you all and my oem manuel have taught me a thing or two I am on to more detailed questions...
First off I may have goofed a little, I changed the lower unit oil today, I used mallory Type C and filled from the bottom till the oil came outthe vent hole, then hurried like hell to get the drain fill screw back in.... sounds all good right? well my concern is that tomarrow I plan to tackle the impeller....... will I lose that fresh oil when i change the impeller or is it sealed and wont matter?
secondly I would love any "tips" to make tomarrows impeller job easyer, or to know anything to "look out" for......
finally there are two..... holes.... drains.... something on the side of the boat (72 larson shark 1600) that I am unsure what they are.... both are on the starboard side, the one toward the rear seems to easily be above waterline (never had the boat on the water yet) and the one toward the front it lower mabey at the waterline even possibly below.....
I did some research on Bilge drains, and my craft does have a bilge pump switch on the "dash"....... when on the water do these need to be pluged or open are they both bilge related or??????????????
THANKS!!!!!
THANKS!!!!!
