Total Basshole
- Jul 16, 2012
- 14
I have been trying to get this motor working with minimal knowledge of motors in general. It sat in the water on a desert lake for a few years unused. I have replaced the plugs, checked the fuel pump/filter(looks fine), changed the lower unit oil and rebuilt the carburator. The motor starts on the first pull and runs ok on high idle, but it will not run at low idle, it just sputters out and dies (if it matters cooling system seems to be working, plenty of water discharge). The motor starts and runs with the choke butterfly just barely open (choke almost all the way out). When you try to open it any further(push choke in) the engine seems to cough, sputter and die every time the butterfly passes halfway. I have tried running it at high idle for several minutes to warm up the engine, but I still have the same problem with the air intake when I try to open the butterfly all the way.
Can anyone give me an idea of what might be the problem? I have reached the small limit of my knowledge on motors. Thanks in advance,
