72 50hp Johnson cylinder seems to be running on one cylinder
robtown
I have a 72 Johnson 50hp that I can't get to idle.
In the last three years its had a new power pack, a new timer base, new coils, a fuel pump and 3 carb rebuilds.
It runs with no knocking on muffs with the start lever advanced a little.
And we've even had a couple summers of running around and pulling the innertube and such, but it's just never idled well.
I decided to chase down why this year.
This morning I was poking around and I realized that if I unplugged the #2 cylinder it made no difference, it ran just the way it always has.
Can't unplug #1, it won't run.
I haven't got my hands on a compression tester yet, but stopping the cylinders with my thumb feels "similar" on both cylinders.
I've swapped coils and tested spark to make sure I was getting fire to both cylinders.
Why would #2 not be firing if it has decent Compression and spark, and a clean carb that appears to be working correctly? Reed valve?
robtown
Re: 72 50hp Johnson cylinder seems to be running on one cylinder
Update.
I tried unplugging cylinder #1 and starting it.
It cranks and sounds about the same as if I cranked it with just cylinder #1, but it only runs for about 2 seconds and quits.
I swapped the sensor inputs from the timer base to the power pack and swapped plug wires, same thing.
I put it all back together and cranked it with both cylinders hooked up by jumping the starter so I could watch it.
It cranked perfectly, and after about two seconds it started arcing from under the boot to the plug base on cylinder #2 (about the same time span as it'll run on cylinder #2 alone). Keep in mind I've already swapped coils and wires around to make sure I didn't have a bad coil.
It seems to have some sort of electrical problem that causes #2 to not fire after running for one or two seconds, but there's still power going to the #2 plug...
Anybody?
robtown
Solved the spark issue. It's running pretty smooth on the muffs.
Still need to get her wet and make my final adjustments...
I had the bottom carb idle screw out 1-1/8 turns since I just did carb kits, it was flooding the number 2 cylinder.
I lightly reseated it and backed it out 5/8 of a turn as per my manual and viola, two cylinders firing and no arcing!!!
I love this place...;)
A manual is a must have, but 20 minutes of searching will find you an answer to most any issue you come across.
derail
Im having the same problem with my 72 50hp Seahorse. I put a set of new plugs in the top looks used while the bottom looks like it just came out of the box? i all so can hold my hand over the bottom carb mouth and the motor idles up. I think I may have a vacum leak!
